Radeon 9200 freezing
djddrop
I am having an issue with my system. The first problem I am having was my system getting the BSOD when playing video or even trying to test the card with 3SMark03. So I unistalled the drivers and my AGP chipset drivers, restarted and reinstalled the AGP drivers from the mainboard CD. The I installed the ATi driver pack with Catalyst control center. For a few hours it ran great. No BSOD, no restart and no video freezing.
Now I'm getting a freeze when opening any fullscreen windows or playing video. Most of the time the Catalyst control center will reset the GPU and I can continue. The rest of the time I get a blue screen. The next blue screen I get I will try and snap shot the bottom half of it and post it.
My System:
CPU: AMD Athlon XP 2200+ OCed to 1.93 Ghz
MoBo: VIA KT600
Ram: 1.5 Gb DDR 233
GPU: ATi Radeon 9200 SE
Thanks ahead of time!
*EDIT* Ok, now it's doing this weird refresh lag when scrolling pages. Basically I can watch it refrsh the display in a horizontal line from top to bottom.
vixro
It's possible your computer is showing old age as well, could be the hardware just as much as the software.
I had a problem like that refreshing issue when my video card wasn't getting enough power, considered a faulty PSU?
Puer Aeternus
In your head (Ottawa.Canada)
its a good point...Is this a machine thats recently built...has it been in steady use and recenlty upgraded w/ this video card....or collecting dust since the 2nd gulf war?
i'd check the chipset first..u are using the ones that come on a disk thats as old as I am.
djddrop
djddrop
I will agree to the fact that the computer is old. Verywell could be a bad AGP Card. This system was built in '04.
djddrop
djddrop
The last drivers to support the Radeon 9200 were the 6.11 drivers. Not sure what drivers you are using but if they are older than that you should give them a shot:
http://support.amd.com/us/gpudownload/Pages/radeon-prer300-xp.aspx
Nah, not evn trying anymore
The GPU is dead. I started getting artifacts like crazy, the temp was at 120C and it died.
A friend had an old PCI card so I'm on that right now. Crappy graphics but I'm still up and running.
Thanks for the help tho! Greatly appreciated.
