- May 20, 2004
This is getting really, really aggrivating. I have a Radeon 9700 Pro card in my rig that is running the stock clock speeds, yet it still seems to have significant heat issues. My case is a large chieftech with plenty of fans and not much hardware in the case. I'm running two hard drives, and no PCI expansion cards.
What happens is, if I leave the computer on for an extended period of time, even idle, then I try to play a game, like BF: Desert Combat, I get all kinds of artifacts. If I boot from a cold start, I can usually get a few hours of BF: DC in before any artifacts show up. Unfortunately, when playing DOOM 3, the card seems to heat up immediately. I get black speckles all over after just a few minutes of playing. I have to actually open my case and point a stinking 10" floor fan like the one below directly at the video card. This just doesn't seem right Why in the hell would Sapphire provide such poor cooling with their card? Is there anything I should check. My machine is overclocked (FSB 190-200 range), but not my video card. Should I turning back my AGP speed? Also, what is under that metal plate that gets so hot? I was going to order the VGA Silencer from Arctic cooling, but I don't think it's the GPU that is heating up...
Below are some pics of what my card looks like, with notes:
The metal plate in the upper right corner of the PCB get's really hot. I have a hard time keeping my finger on it. The PCB where the processor is doesn't appear to get that hot though.
This is the top side. I have this type of heatsink and fan.
This is the stinking fan I have to use. Do you know how much airflow that is??? More than you'll get from a 120mm, that's for sure
NOTE: If this sounds familiar, it's because I've posted before. I have the side mount fans now (120mm) and I still have these issues I did not order the VGA Silencer though.
