Radiator for 1/2" tubing system
Westside05
I'm looking for a radiator that fits to my 1/2" tubing.
already bought 1/2 barbed blocks, reservoir, pump but WHERE CAN I FIND A RADIATOR(without modding if possible)?
ILikeMy240sx
University of Michigan
Buy a heatercore, get your dremel out and cut the barb off until theres about 1in left (some people didnt cut the barb so this is not necessary) Boil your tube and slide over it.
It will save you money and be just as good
W
Westside05
Buy a heatercore
lol buying a dremel would cost more...well since it will be useful soon or later I'll go buy em tommorow.
any recommendation on heatercore? chevy chevette 86?
Korndog
California
that ones pretty good
a lot people like caprice though...
but as long as its not aluminum, and can fit in your case, its all good.
W
Westside05
can someone find me one on ebay or paypal-compatible store?
I don't have cc but paypal....=\
Yuriman
The OCFORUMS
I used a hacksaw to cut off the barbs before I got a dremel, works just as good. You can get a good heatercore for as low as $15, or if you want to go the easy route you can go with a dtek unpainted radiator. Basicly, its a chevette heatercore with barbs already attached.
Bamboozler
Personally I'm going with the heater core from a Ford F-250.
Go to napa online and search part number: BK 4603347
5/8" inlet and outlet so I'm thinking I can make the 1/2" hose fit without too much work. It is also a little larger than the chevette and cheaper!
