kieronholden said:if you plan on using a radiator from a car your gonna need a more powerfull pump than you are with a heatercore, if space isnt apreoblem then you can use the rad and you probably will get good results with it provided you have anought airflow through it (try 4 120mm on a shroud 1.5" from the rad)
