Radiator idea for H2O cooling
M
Mark
Guest
While visiting my family up North, I found something that may be an interesting substitute for a radiator. Most Northern homes use floor mounted radiators for heating during the winter. These radiators are essentially a straight run of what appears to be 3/4" Copper tubing/pipe with Aluminum fins mounted in a 3"x3" square configuration. The straight run design of this radiator would mean virtually no pressure drop and, obviously, the design seems to work well in the homes that use them. A simple mod of adding some hose barbs would make these quite usable, though fan mounting may be hard to do. I was thinking that these radiators could be mounted outide, in colder climates of course, and that no fans would be needed in that configuration. If the radiator is placed outside one would need to use antifreeze though to prevent major problems. Anyway, what are your thoughts on this idea?
I live in Minnesota, which is the coldest state other than Alaska, in the USA. This would not be effective at all in the summer, we still get 90-100 degree weather. In the winter it would be very effective. Rather extreme, unless you're going to cut holes in your walls you'll need to be by a window, it's that screen with the really high resolution that you can't control.
