Radiator Mount
Xerka
Colorado
I just got new case but it is not big enough to hold the radiator on the top back wall. So I was thinking would it be fine if I mounted it on the very top of my case. I thinks it will work fine, I have just never seen anyone do it. Suggestion, Concerns, Ideas?
Thats the best way to do it...a nice item to add, is a diffuser on the top of the case to make the hole you cut not so ugly looking...
Well you never want a radiator's exhaust going in to a case...so an in case radiator will work ok, but your blowing warmer (ie. case air) throught it...externally monuted are the best but I don't like all that s%#t around my system, I prefer internal radiator with ducting...
