- Jul 19, 2013
Okay, I may be pushing it a bit here regarding radiator size (might be way too small)...
A good while back I bought the "EK-KIT P280" which have served me very well over the years.
It consist of a CPU block, a D5ish pump with a built-in reservoir and a EK-CoolStream CE 280 radiator (45mm thick).
I'm building a new hard tube rig and would VERY much like to re-use all the components.
My new hardware:
Gigabyte Aorus Master X570 (watercooled CHIPSET)
AMD 5950X
PowerColor Liquid Devil RX 6900 XT
All water cooled...
2x Arctic P14 PWM PST CO Radiator fans (140mm)
Do I need a bigger radiator?
I'm hoping "no", but I'm having a gut feeling that tells me otherwise....
Thanks
My new hardware:
AMD 5950X
All water cooled...
Thanks
