OK, I've decided to try my luck at water cooling. I wanna hit 1ghz with my Duron and the Alpha just isn't going to cut it. I've been going through all the info on water setups that I can find. I've decided to go with a radiator insted of a water tower due to size and being able to transport the system. Any particular radiators that you guys would suggest? I'm also gonna hit the local salvage yard tomarrow and see if I can find a good deal on a heater core there. Let me know what you guys use and what ones you've had the best luck with.
