RAID 0 stripe size
JT
What stripe size should I pick when RAIDing 2 7200RPM 40gb hard drives.
Can pick from 4k, 8k, 16k, 32k, and 64k
Thanks
It depends on what file system you are using. I havent quite optimized my system for NTFS yet, so if you are going to use NTFS, then I would ask somebody else. On the other hand, if you are going to use FAT32, then I would suggest a 16KB stripe size and 16KB cluster size for your file allocations.
I just got done reading Adrian Rojack's RAID review and 64K seem to be the worst. It looks like 16k is probably about the best compromise. I haven't benched my current raid at 16k yet but when it was 64k the drive index came out at 20k for the onboard Highpoint Raid - which is way below my original Raid using a PCI promise card, that gave me a DI of 31k so I am quite disapointed in my new Soyo P4S board's RAID performance. I tried to use my old Promise PCI raid but I can't get the Soyo to load it's bios :mad:
16k is the way to go. It optimizes the drives the best and gets the most out of a RAID set-up. I would have to say that 95% of the people with RAID use 16k stripes.
very simular question to the AGE old question of LATENCY vs BANDWIDTH (Small Cluster vs Large Cluster)
