Raid 0 what recomendations of drives
JamesMore
I was looking to setup a game/work system, and do a raid 0 setup. I was trying to see what people recommend for drives.
I don't think I can go with SSD or raptors due to the current cost. I have a Western Digital Caviar Black WD1001FALS for my storage. so should not need that much space for the OS and games.
Any ideas ?
ibitato
Spain
Any ideas ?
get 2 HDDS
any 7200 rpm 16 oe 32bit cache from WD, or Samsung, Hitachi would do. Look for the lowest access time and get 2 equal ones (if yo can, if not , as long the specs are pretty much the same yall be fine)
a RAID0 with 2x500GB HDDs its a 1TB of storage......
Now, be prepared to run daily backups; RAID 0 on the mobo chip it's easy to break; any BSOD ot hang can produce the raid to go unstable and you will loose all your data.
J
JamesMore
Thanks for the ideas I found Tomhardware has a list of drive speeds so might start there and then use google to confirm. I did not know with raid 0 that you get to use both drives as storage. I guess I am use to raid1.
I was thinking if that's the case maybe to stay small 250gig = 500gig usable, I dont want to go too big other wise I will start to dump lots of crap on there and then not have enough space to back up on to. I have the 1 gig storage drive so I can backup there each night and then do a weekly backup to an external drive.
Plus dont want to spend too much as next year if SSD come down I could move to that media.
deathman20
High Speed Premium Senior
Ideally you'd want to go with 500Gig (Single Platter) drive for speed reasons. Though a personal fav is the 640Gig WD Black drives.
Going to smaller 250Gig drives, while you might not be worried about space at that point you might as well pick up a single 500Gig single platter drive and get nearly the same performance.
J
JamesMore
Yer I did some searching and the 250gig drives are some times much more than the bigger drives (I remember getting a 20 gig disk and thinking I would never fill it so might go with bigger.)
I have been looking at the WD Caviar Black 640 GB SATA Hard Drives ( WD6401AALS ) as well deathman20 :) not sure if that's the same model you referenced.
What single Plater 500gig drive do you recommend.
J
JamesMore
both of you recommend a single platter but I through the blacks had 2/3 platters ? ,
Just the size + cost for the raptors is very off putting. So will stay with normal disks.
J
JamesMore
Not sure if they have changed in later models but looking at the spec sheet it does show multiple platters for each drive
http://products.wdc.com/library/specsheet/eng/2879-701276.pdf
J
JamesMore
Yep I was right
WD5001AALS-00L3B2 single plater
WD5001AALS-00L3B
So its going to be pretty hard to find a WD5001AALS-00L3B2
