- Dec 16, 2001
- Port Richey, FL
I just upgraded my old system (specs below) with an Epox 8kha+, duron 1Ghz and 512 MB samsung ram. after swaping the boards, the raid isn't working properly. I can see the drives in windows, but if i try to move or copy something from them, the computer locks up after about 30 seconds-1minute of copying. I'm currentl booting of the 27 GB WD drive, and as long as i don't access the array, it's fine.
Old system:
Abit BP6 with 2x celeron 400 @ 400 (6x66 mhz)
WD 27 gb 7200 rpm on Highpoint controler
2x WD 60 gb 7200 RPM on promise ata 66 card moded to fastrak 66
pioneer dvd primary master
nec cdrw secondary master
ls 120 secondary slave
new system:
Epox 8kha+
duron morgan 1g (unlocked) @ 10x100 mhz
WD 27 gb primary slave
NEC cdrw secondary master
ls120 secondary slave
2xmaxtor 60 gb on same promise controler.
any help is greatly appreciated.
*edit:
I'm using windows 2000 pro and have done a clean install on the 27 gb drive since swaping the boards. I've also tried using a different PCI slot for the promise controler.
Old system:
new system:
Epox 8kha+
*edit:
