- May 10, 2003
- Helsinki, Finland
Hello, I have this very annoying problem at the moment. Everytime I try to copy something from my harddisk to another (or even from one partition to another), I get a bluesscreen that says something about FDCBNT.sys having some sort of problem. The computer is very stable as long as I don't copy/move anything, wierd huh?
This is what I have inside my case:
Silverstone 480W
Asus P4P800 SE mobo
Intel P4 3.0C
2x Kingston HyperX 256MB (BH-5)
PNY GF 6800 GT
ADSL PCI-modem
Intel 10/100 PCI-card
NEX 2510 8X DVD-RW
2x Maxtor SerialATA 160GB in Raid 0 (after that partitioned to 20,80 and 200GB partitions, as the 20GB is for Windows XP Pro SP1)
1x Maxtor 120GB IDE 7200rpm 8MB cache
1x Maxtor 60GB IDE 7200rpm
This is what I know:
- The problem is not caused by lack of power in the PSU, as I have tried to disconnect all devices I don't need (ADSL-card, Intel 10/100 NIC, both IDE HD's and the DVD-RW). The voltages are always stable and quite good as well.
- The problem is always the same, I have tried installing XP several times, and everytime I get the same error in the bluescreen
- Memory has nothing to do with this problem, since I have tested with other modules as well
- The problem only occurs when I'm using my harddisks a lot. When copying small files everything is ok.
- The bsod is usually occuring randomly, but not as I have a fresh copy of Windows installed.
- The bsod occurs also when moving files&folders from one partition to another inside the Raid.
- I tried searching the forums, but no-one seems to have problems with fdcbnt.sys bsod.
Am I not seeing something here? Anyone of you know what can be done? If you need more info about anything (drivers, specs, BIOS settings), I can give it to you.
Silverstone 480W
Asus P4P800 SE mobo
Intel P4 3.0C
PNY GF 6800 GT
ADSL PCI-modem
NEX 2510 8X DVD-RW
