raid question about drive cache
Crash893
"The man in black fled across the desert,
i have two wd 80mb 7200 8mb drives
i am toying with the idea of putting them into raid on my ga-7n400 pro2
now i hear a long time ago that if you put them into raid then you get so mething wiggy with the cache
it this true or false
if true what does it do
also
if i have windows xp installed on drive c:\ in the primary ide and nothing of my d:\
can i move them both over to the primary raid controler and
1) have xp not wig out
2) not need to format them both again just setup the raid 0
3) split them later on if i need more storage with out illeffects to the data
disk11
Charlotte
I don't understand what you are trying to ask.
As for your 3 listed questions below:
1. XP and everything else will be gone, so backup all of your stuff before creating the stripe
2. No, you will have to format them after setting up the array
3. Will not work. What a RAID 0 array does is breaks data up into a specified size call the data stipe size over the two drives. For example, if you save a 32k file to a drive/partition on the array and you have a 16k stripe, the first 16k will go to one drive and the 2nd 16k will be on the other drive. Breaking the array will cause all the data on it to be useless.
I would only setup a RAID 0 array if you have sufficent storage to hold all the important stuff in case a disk fails and you lose all of your data or you deciede later you don't like RAID 0.
Crash893
Crash893
thanks
basicly im asking
i hear that when you do raid 0 with to hdds with 8mb cache it will only use 2mb of cache or soemthing to that effect
and it doesnt really utalize the cache
Axis
Lakewood Ohio
Crash893 said:
thanks
basicly im asking
I have been working with RAID 0, 1, 5 for about 10 years, scsi and ide/sata. I have never heard of this.
