RaijinTek Nemesis testing results
manu2b
These are the results for the Raijintek Nemesis and i7 4790k/Asrock Z97M OC Formula.
2 mounts.
Tested:
- stock/1.159v (default voltage), default fan profile and max fan profile
- 4.7GHz/1.27v, max fan profile only (as fans ramp up to [email protected] profile)
Ambient 24°C.
Mount 1 Stock/FAn Default
Mount 2 Stock/Fan Default
Mount 1 Stock/Max Fan
Mount 2 Stock/Max Fan
Mount 1 4.7GHz/Max Fan
Mount 2 4.7GHz/Max Fan
trents
Senior Member
Looks like that cooler is taller than your case is wide but picture angles can be deceiving. Can you get the side panel on? Are these temps then achieved in (as it were) an open test bench environment?
manu2b
manu2b
Yes, the cooler is taller (like half an inch) but the case is not a case anymore, it's more like a testing bench, answer to question 2 ;)
I've added a third fan this morning (used to be a stock Hyper 212 fan), and temps dropped 2/3°C extra.
The Raijintek stock fan are quite efficient for they rev (1200RPM max), but I am sure it's possible to shave few more degrees with higher speed fans.
trents
Senior Member
I find that moving from an open test bench environment to a well-ventilated closed case environment adds about 2c to max temps.
It would be interesting if you had a Noctua NH D14/15 to test in that same environment.
manu2b
manu2b
Yep, thing is my former rig's been stolen... including the NH-D14.
SO, not much I can do.
trents
Senior Member
So you live in west Africa just about on the equator, huh? Do you have high ambient temps or do ocean breezes help keep the temps down? Sorry to hear your rig was stolen. How'd that happen?
