As the title suggest, my motherboard seems to have an issue reading memory. I have 2x2gb sticks and the computer will not boot unless a specific stick is in the A1 dimm slot. The computer refuses to boot if that same stick is in any other slot and when placed in the A2 slot a beep message indicating I have no memory installed occurs. The other stick seems to not work in any slot including A1 and the computer will only boot with two sticks if they're in A1, A2 but still only reads 1 stick.
This problem arose after I installed a Hyper 212+ cooler. I have read of similar issues due to the instillation being to tight and remedying it by loosing, however I loosened it and the problem still persist. I fear I might be too late and the damage has been done. I do need all 4gb to be accessible so any help or advice is welcome.
As for the memory itself, the stick that can boot with the computer reads no error, yet it still only works in that slot. The other stick I received after an rma of a previous one. I can assume the stick works fine, but I can't test it.
I have also updated my bios to the most current version as well as re-installed the stock cooler. I fear the pins in the mobo socket have been damage and I really hope that is not the case.
System:
OS
Windows 7
CPU
Intel Core i5-750 2.66GHz
Motherboard
ASUS P7P55 LX LGA 1156
Memory
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Graphics Card
XFX HD 5850
Hard Drive
SAMSUNG Spinpoint F3 HD502HJ 500GB
PSU
CORSAIR CMPSU-650TX 650W
System:
OS
Windows 7
CPU
Motherboard
Memory
Graphics Card
XFX HD 5850
Hard Drive
PSU
