ninthebin said:yeah I have always thought they look like the most useless thing there...if they put a couple of fans into the heatsink side on...not on the top like that then you would have some that would be cooling...not just moving air about your case
Sonny said:I'm going to have to disagree with you guys that think it is useless to add a heatsink to your ram sticks. The problem mentioned here is a failure to attach them properly making them seem useless but it isnt the heatsink's problem. If you need to increase yur VDimm to anything over 2.85V your going to want them there or you fry your memory in a short time frame. My Kingmax runs hot cause I need to run them at 2.95V just to be able to run at CAS2 2 - 6 - 2 -1T - 2T - 1T @ 155MHz/310FSB which is far away from its SPD of CAS2.5 3 - 7 - 3 - 2T - 3T - 3T @ 166MHz/333FSB.
mbentley said:what did you use to attach your ramsinks out of curiousity? thanks.
Lithan said:ramsinks are crap... the surface area isn't that much more than the chips themselves... combine that with the chips being INSIDE NONCONDUCTIVE PLASTIC... combine that with the hit you take from the 99.99% chance of poor transfer from ram to heatsink... trust me a frant case fan that hits the ram is twice as effective.
Oh and by the way... on most memory manufacturers it voids the warrantee. And I've got ram which was shipped to me dead which I believe was cooked by the thermaltake heatplate/fan attatched so the scum****er sold it as working and pled ignorance. Yeah you bet your *** I'm filing fraud charges.
In other words. I wouldn't do it if I were you.
