Ram Questions
fcairforce
Indiana
I have several questions regarding a ram upgrade I would like to get.
I have heard that a latency of 2-3-2-6 is worse than 2-3-3-6 becuase the middle two numbers arent' the same. True?
Also, I'm looking for Corsair XMS dual channel pc3200 low latency 1gb, but its nowhere to be found. :cry:
I have a SLOW stick of PMI ram in my system now. If I got a fast stick with low latency of a different brand,
A) Would they work together
B) Would the fast stick be slowed by the slow stick
C) Would I be better off getting another stick of PMI instead of Corsair
Highly embarrased for getting sucky ram to begin with :cry:
Know Nuttin
Senior Member
Ontario, Canada
Welcome to the forums.
2-3-2-6 is better than 2-3-3-6. Not a huge difference but it is better.
2 different sticks should work together fine. getting them to run in dual channel, however, is a bit sketchier. It's always good to stay with the same model when not purchasing a dual channel kit.
fastest stick would be slowed down by the slower module. Like running a 3 legged race, you can't run faster than the dufus beside you ;)
K4mui
Hessen, Germany
Since you're running a Pentium 4 (you do, right?), timings should be relativly irrelevant.
You should try to achieve a high fsb, and here is the problem with keeping your old ram.
For the record: on athlon xp the "RAS-to-CAS-delay" is the timing- even 11MHz of fsb don't compensate the difference between "3" and "2"- of course, "2" is the faster setting.
F
fcairforce
Indiana
So I would be better off just using the dual channel sticks even though there would be more ram if I had them both in?
And my current (bad) stick is single channel. Are you saying it would be hard to get my new sticks to run in dual channel if I keep my single channel stick in?
P4 2.6 800mhz fsb HT
F
fcairforce
Indiana
If there is dual channel ddr ram, then how would a gig of single channel compare to 512mb of dual channel ram?
