RAMBUS o/c
evilted26
I've decided on using RDRAM for my next machine, and I had some questions I thought you folks could answer. First, I've noticed that many people have trouble getting higher FSB's when using more memory. Any idea why? Is it a heat or voltage thing? Also, I can't decide on ECC or non-ECC. Does one clock better than the other? I plan on doing both a volt-mod, and I'll have 2 delta's blowing in from the side over the memory. I'm using watercooling, and I'd like to hit 150FSB if I can.
HELP!!!
Lt. Max
Seattle, but im Estonian
you dont need deltas you could get lower /quieter fans for that to blow across, since ram only generates a few watts of heat. you should get non-ecc ram, it oc's a lot better
Tweak
RAMBUS by nature operates at higher clock speeds. It has less of a "reserve" in it than DDR does. Also it is a serial interface that can concentrate all RAM activity in a single chip whitch makes it even lass stable than DDR.
