some good points, but the real champ is 845
theflyingrat said:
Well, it looks as if the biggest lead RDRAM ever had in any of these tests was in the SANDRA memory bandwidth benchmarks.
Know what that means?
Approximately zero. Especially since the difference there, even, is only less than 1%.
I agree 100%. Use synthetic low level benchmarks very carefully, and don't try to read too much into the result.
Originally posted by theflyingrat
Sure, RDRAM does have the lead in most of the real-world tests, but by a very, very, very narrow margin.
Quake III demo - RDRAM wins by .8 fps. That's eight tenths of a frame per second. Push.
3DMark 2001 - DCDDR wins by 5 points. Push.
Comanche - RDRAM wins by .04 (four hundredths) fps. Push.
CodeCreatures - RDRAM wins by .3fps. Push.
Another good point, as the application tests show a near parity between RDRAM and the DDR alternatives. But the really important observation is how well the 845ge board fared. It actually beat both RDRAM and dual channel DDR in Quake3, and bested the dual DDR setup in 1 other test. Of the four remaining, the 845ge machine finished with essentially identical (although fractionally lower) score as compared to dual DDR, only being bested by a substantial margin on one of the six tests. And since the only reason I bother to keep my fast PC fast is that I play Quake3, you can see why I just bought a board some would decry as obsolete, a BD7-II. Aided by PC3500 memory performance (achieved with the cheapest PC2700 ram I can buy, which is no more expensive than a pair of half-sized PC2100 modules), this is at least the equal of the RDRAM and dual DDR alternatives, and may actually be unmatched in some areas while at no point being seriously outclassed.
The comparisson to nForce has no validity here. They are chipsets for ENTIRELY different CPU architectures. nForce would have been a much bigger success if the Athlon XP was as bandwidth-hungry as the Pentium 4.
I disagree here, there is a valid lesson to be learned from nForce and nForce2 boards. The lesson is the performance of either is nearly identical between the single channel and dual channel implementations. The basic virtue of the chipset is the biggest factor, not how big the numbers are. Granite bay is here to remind us that this is not a characterstic unique to the nForce. It also has a desperately tough time outperforming the single channel 845 series, even though the numbers are twice as large. And the only reason a P4 is "bandwidth hungry" is that it is faster, with a substantial edge in working frequency. The faster a chip processes data the more difficult keeping it stocked with data to process becomes, and the greater the gains possible through higher memory througput. But as this is problem wrought by the extreme speeds these cpus's attain, there are worse problems one could have.
Numbers don't really matter... I see many folks actually asking which dual channel DDR or AGP 8X products they should replace their (usually perfectly fine) existing motherboards with. The truth is if your current rig is optimized for value presently, none of this new stuff changes the selection. A properly built high fsb 845e, pe, or ge system with PC3500+ memory speed will at worst equal the newer alternatives, and in some cases outperform them. Just like the tiny performance edge PC1066 RDRAM shows doesn't make it the platform of choice for most, neither does the edge possesed by dual channel DDR. In reality getting a single channel DDR system running the ram at 400MHz and up is just as valid a solution to the (only comparitively) limited bandwidth as going to the hideously expensive dual channel RDRAM or new (and therefore costly) granite bay dual channel DDR solution.
If I needed a board already I might consider granite bay, but only after it has matured a bit, the price has relaxed, and the overclocking ability has been proven to surpass what the 845 series allows. As we've seen at equal clock rate granite bay's edge varies between unimportant and non-existant, so it better be able to keep up in the MHz race lest it be embarrassed by the lowly old 845e. To rip out a perfectly optimized 845 board at present to pursue the "2" implied by dual channel DDR and the "8" in 8X AGP is entirely a giant step sideways, and one that drains the old NV30 fund at the same time.
The beautiful fact about Granite Bay is its ability (like in the above tests) to run cheap PC2100. 512MB of PC2100? That's two 256MB sticks. $150 for two sticks of Crucial (very good memory by reputation; I also know this firsthand.)
Single stick of 32-bit, 512MB RDRAM? Cheapest I could track down on Pricwatch is $285 for Samsung. That's a $135 difference. Now, even if the GB boards cost $80-100 more than 850E boards, you still end up saving some cash, while basically getting the same performance, and in all likelihood, much better overclocking results.
I agree the economics do not favor RDRAM, but they don't really favor granite bay either. You can buy a good 845 board for 75-100 bucks, a 512MB Kingston Value Ram PC2700 stick for 150 (or less, 144 at googlegear last week), and have equivalent performance to granite bay (which is essentially identical to RDRAM) for even less. And the overclocking abilties of the 845 series chipsets are well known, with 160MHz + FSB and 430MHz + memory speeds obtainable very easily.
....it's basically all over for Rambus, at least in the consumer PC market.
I agree there, RDRAM tested the limits of reason when it had a substantial performance edge, and of course the DDR competition has improved to a point where there isn't much of an edge to point to. But the important fact is that single channel DDR solutions are just as competitive with RDRAM as the dual channel ones are. Two may be bigger than 1, but PC performance is a subject that requires entirely more complex evaluation to quantify accurately.
The real death of RDRAM stems from Intel's decision to stop pursuing this particular architecture. In the P3 days RDRAM was slower, but hideously expensive. Intel forced its use on the market in an attempt to obviate the AMD question. Just like the initial adoption of AGP, the move to RDRAM was a marketing ploy designed to make the non-intel platforms look second-rate as they could not offer these features. Of course the question of whether these features were of any value had an answer so obvious that Intel gave AMD more market share than it ever dreamed as AMD was able to adopt AGP by the time it actually started to matter, and took the substantially more elegant DDR solution to the memory throughput question. Without the 300lb gorilla of Intel's will to to pressure the adoption of RDRAM, no one will be using it. The fact that Intel is moving to a dual channel DDR is not responsible, just the fact that they are moving.
nForce2 is a slightly better chipset than the single channel KT400 Via on the AMD platform, but this is not because it is dual channel. Single channel operation of nForce2 reveals that it is a more refined chipset of higher performance than is KT400, with the dual channel calling card just a sideshow. When you compare to the 845 series DDR chipsets, this lack of refinement does not exist. As such dual channel DDR alternatives have a considerably tougher time impressing me. Sure more memory bandwidth is a worthwhile goal, but improvements in single channel memory technology such as the 650MHz DDR SDRAM graphics cards already use or DDRII are just as valid of ways to pursue this goal. And the current single channel DDR setups don't particularily suffer from their situation at present afforded by system ram than runs at "only" 400-450MHz.
