FIZZ3 said:
System efficiency is similar and only a small factor. The numbers I gave do hold relevance.
FIZZ3 said:
The above quote truly is pseudo-knowledge. The 6ns vs 32ns numbers have no indicative relation to real latency. Judging from this text of yours, you apparently think Rambus latency is 4 times that of DDR...
FIZZ3 said:
Hardly:
http://www.tech-report.com/reviews/2002q4/i845pe-ge/index.x?pg=5
A 23% difference is more like it. Compare this to the DDR333 2.7Gb vs 4.2Gb RDRAM bandwidth (a 56% difference). That is a favorable trade-off by all accounts.
*Dual channel is not taken into account here because it's latency and efficiency haven't been properly measured yet..
FIZZ3 said:
I did not say outlive. I said both would become obsolete in about a year. Also, claiming that an installed base will somehow postpone obsolesence is irrelevant to the current discussion we have on the memory's performance.
FIZZ3 said:
2) DDR memory is possibly more dead than rambus is.
larva said:The thing is that system efficiency would affect is the difference between theoretical bandwidth and realized bandwidth. The point is that bandwidth is but one aspect of a memory subsystem's performance. The notion that RDRAM must be superior because it has greater bandwidth is pure nonsense and as such has no relevence to a educated discussion of the effectiveness of the two architectures as a whole. It's like trying to point to Sandra numbers and and say they tell the whole story, except you just calculated the result instead.
Try again, I said only that the large difference in latency of the devices was indicative of the substantial difference in latency of the memory subsystems. Unlike your above attempt to fashion numbers that support your arguement and exclude the complexity of the subsystem as a whole, I did not attempt to extend this one particular fact into a statement of the realized latency difference.
Huh? How exactly do you achieve the 4.2GB RDRAM bandwidth without a dual channel implementation? And the attempt to declare the bandwidth discrepancy more important than the latency difference is short sighted. The particular application's needs will determine which is a bigger factor, not a "56 is bigger than 23" leap of logic. Most home user tasks are far more sensitive to latency than bandwidth, meaning that the two percentages need not be equal to have an equal (or more) affect on the application performance.
To say it is "more dead" describes a lack of lifespan. You started out saying RDRAM had a longer lifespan to look forward to than DDR, but now backtrack to say that you didn't. Obsolence has little impact on how long DDR will continue to be produced and used. You may declare it "dead" from a technical viepoint, but the continued evolution of this memory type is assured along with the production of the current type long after RDRAM will be just a memory.
FIZZ3 said:
And I did not claim bandwidth was all there is to it. See below.
FIZZ3 said:
Conclusions:
1) DDR can't even match PC1066 stock speed at 183Mhz 3:4 which makes the ram run at DDR 488 already.
FIZZ3 said:
Sure you did not state it explicitly, but the strong suggestion lurked beneath the surface, especially in conjuction with words like "huge" etc. My little link provides clearer information than you gave IMHO.
FIZZ3 said:
Rambus on the P4 is always dual channel. thus the 4.2Gb.
FIZZ3 said:
I did not declare that bandwidth weighs more. I said 56% bandwidth is more valuable to me than 23% latency. And I might add that the benchmarks are with me on this one, however small you might deem the difference.
FIZZ3 said:
Note that I also said "possibly". I'll explain why I said this: DDR-I will not evolve to higher speed grades than 400 at the max. Rambus has lots of plans to go beyond current PC4200. This goes from PC1333
larva said:You conclude that DDR cant match speeds with RDRAM because it has to run at 183 3:4 to provide the same bandwidth. This is false. Due to the latency advantage DDR posses it does not need to match the raw bandwidth to provide a level of performance equal to RDRAM.
I am well aware of this fact. Rambus went dual channel in the P3 days because of the miserable failure of single channel systems, as even their substantial edge in bandwidth still did not raise their performance to SDRAM levels. So why this statement, surely it must confuse more than me...
No you infer that the two weigh equally, and therefore the 56% edge in bandwidth is more important than 23% in latency. The truth is home user tasks are vastly more sensitive to latency than bandwidth. In this setting (the one the users of this board almost exclusively are in) the latency and bandwidth differences are a wash. For applications that even equally benefit from bandwidth, (not seen in the vast majority of home user tasks) RDRAM shows an edge. And if you run SPEC ViewPerf 7 for a living, RDRAM is god. I guess you've found a usefull income from running SPEC ViewPerf
Rambus can plan what it wants, without Intel pressuring the entire industry to march to a RDRAM beat few enough people will care enough to make the production of such memory econimically feasible.
And as pointed out before DDR-1 that runs at 650MHz has been comercially available for over a year. The fact higher clock rates haven't been used for system memory DDR is due primarliy to a lack of demoand for the bandwidth it provides. The manufacturers have increased DDR speed implementations as fast as needed to keep up with the bandwidth demands of the audience they are playing to.
OC-Master said:RD-Ram is pathetic compared to any Dual Channel DDR Configuration!
Second, DDR ram is fully backwards compatible (PC2100~PC3500) and also DDRII which also uses 184-pins.
OC-Master
larva said:Funny, one of your links contains the following statement, under the section "The Final Word"
"With some high-quality DDR-333 memory sticks and tight motherboard BIOS DRAM timings, Intel 845-PE motherboards can give gaming and application performance within a percentage or two of PC-1066 RDRAM products, at a much lower cost. "
http://www.gamepc.com/labs/view_content.asp?id=p4pe&page=10
This was the whole point. Even the relatively pedestrian 845PE with good ram an intelligent bios settings virtually equals PC1066 RDRAM's performance for "gaming and application performance". Since we well know the it does not posses the raw bandwidth of RDRAM, this can only happen because of the latency advantage enjoyed by DDR, and it's relevence to home user tasks. Pay as much as you want for a percentage point or two, it doesn't make sense. And hope you don't run into a really hot 845 rig, as it can and will eclipse the perfromance of your treasured RDRAM no matter how highly you think of it.
larva said:I said exactly what your lind states in my original post. You started a tirade saying that wasn't the case. I said the advatage of RDRAM varies between insignificant and inconsequential when compared to a optimized 845 platform using good ram. This is exactly the conclusion your link states. The point about the latency is that it is a bigger factor, which it must be in order for DDR systems to in any way compete with RDRAM ones, because as you pointed out the RDRAM bandwidth advantage is larger numerically than the latency edge of SDRAM. Where it not for the fact that the tasks most use these machines for are more sensitive to latency than bandwidth the results could not be as close as a percentage point or two.
oops said:but you people just don't realize that dual channel DDR is going to be as expansive as RDRAM when it comes out.....so at least it's not going to take any advantage on price.
its full of crackheads that failed in math.Maxvla said:this thread is full of crack heads.
does that make the ram any slower?goldenlight said:The way Rambus stock is going, IT will be no more.
