- Nov 15, 2008
- San Deigo, CA
I had recently got hold of Rampage Extreme and when i finally got my E8600 and Team Xtreem RAM, i'm running into a brick wall or something... i've been up the whole night trying to figure out what the heck is going on.
This problem happens when i tried to install fresh copy of windows 7. at first it boots up fine and i press F8 to choose my USB drive as my boot drive, go through the whole process of doing a clean install, and once it restarts for the first time... it never goes through. it restarts and then it just hangs there, on the LCD Poster it just keeps on saying DET DRAM, now i opened up the users manual and it is no help. then sometimes it says overclocking fail right after the Asus logo, so i choose to set it back to default and all and it still won't work. so i restarted and i went into bios and choose to use Bios 2, and it worked, wet past boot screen, then went to starting windows and so on and after that it took me back to the last step in windows 7 installation, i forgot what it was called, it was right after "installing updates" or something like that. it stay their for like a minute then i get a blue screen, and it restarts and goes back to the post, then to Starting Windows, and on the next screen it says something about the computer restarting unexpectedly, so restart and try installing windows again. i've tried this 7 times with no luck.
so then i tried to see if all of the ram slots work and i think they all work. but i do not know why when the windows 7 installation has to restart, it screws up. Before i switched out the MB, i had BlackOps and Windows XP on my HDD, so what i did was just plugged the HDD with RE and see what happens and it actually booted into windows XP and all and ofcourse all my driveers are from BlackOps so i actually wiped out the HDD using KillDisk v.4.1 and now i am trying to install windows 7 and i can't. all the lights on the MB seem fine. any one ever heard of this problem? did i get a broken or messed up MB? i'm very frustrated. i have been trying to install windows 7 for the past 6 hrs. it is nearly 3AM in the morning and i am nowhere. also when i checked, it has Bios 1202 on. should i flash the bios to something else? everything else seems just fine. I don't think my HDD is bad, and neither is RAM or the CPU.
what is the best bios to have on Rampage Extreme right now?
maybe i should try and install windows XP on it and see if it works or not.
sorry for all the bad wording and all, i'm just tired and frustrated at this point.
If this helps anything at all, my current specs are:
E8600 lapped
Team Xtreem DDR3 1866mhz 2GB(2X1GB)
Sapphire vapor-x 4870
Barracuda 7200.11 500GB HDD
Silver Stone Stryder ST1000W PSU
Cooler Master V8( just got this from fry's on the way home to test out the CPU for DOA before i set up the whole water loop on it)
E8600 lapped
