Ramsink Question?
cmcquistion
IT Director Senior
Tennessee
I'm making some RamSinks for my Radeon 8500.
My question is this, does the thickness of the base of the heatsink have any negative consequences.
I have two sets of RamSinks.
One set I made from a couple old K6-2 heatsinks. The thickness of the bottom plate is about 1/16 - 3/32 of an inch thick. (Aluminum)
The other RamSinks are from a big socket type heatsink and the thickness of the base is a little over 1/8 of an inch thick. (Aluminum) These are the ones I would like to use, but is the base too thick? Will the base act as an insulator, instead of a heat conductor?
Maximus Nickus
Senior Shaman
Milton Keynes, U.K.
Do a search for my thread "My homeade ramsinks" they took me over 35hours!!!!!!!!
But they are perfect for RAM so you can see the dimenions. (next to a measuring device)
I would post pics for us to see, I mean other factors come into play, for instance if the card gets very hot the thick ones will work better than if the card is cool.
M_N
