Hello,
i just upgraded my system to the following
xp barton 2500
2 x corsair pc3200 256meg
msi K7N2 Delta -ILSR mobo
2 x WD raptors in SATA raid 0
i set the raid up with a 64k stripe size. When i ran sandra i got a score of 22,965 is this because of the stripe size? This seems way to low, my 80gig wd got a higher score then this.
I checked the onboard Promise SATA raid controller and it said that the drives were running in mode U5 which is a 100mb/sec....now these drives are rated for 150mb/sec....this can't be right.
this is the score i got in pcmark
http://service.futuremark.com/compare?pcm=1314662
Is it the onboard controller causing the low scores in sandra?
Any help or ideas would be great.
Thank you
xp barton 2500
Thank you
