- Dec 1, 2003
First of all, hello everyone, if you cant tell I;m new here (1st post) been lurking a while and decided after much contemplating to WC my rig..
Anways, on to the question;
Which CPU block will perform better? The Danger Den RBX or the D-Tek whitewater?
Also the rest of my system will be;
Chevette heatercore (according to the folks at PimpRig *my other home* its equal to or better than the BIX)
Danner Mag 2
Swiftech GPU block
and the kicker, preferably 3/8" ID tubing, might go 1/2" if it will get me more than 2-3*c on my temp but from what I gather its a >1*c difference
Thanks all...
Danner Mag 2
Swiftech GPU block
Thanks all...
