- Jan 4, 2005
Intel launched LGA 1366 ( Core i7 + X58 Chipset) platform in November 2008;
in the nearing future, LGA 1366 platform will dominate the CPU & MB marketing that over USD $ 300.
Product transition is always good news to end users.
Although LGA1366 platform is expensive, now we have cheaper P45 to buy now!
To compare with 965 & P35, P45 is more affordable than ever.
You can spend with only USD $120~$200 to buy a P45 with good design & materials.
If you have budget limitation, maybe P43+ICH10R or P45+ICH10 would be your choice.
Of course, P45+ICH10R is better choice.
The leading character today, DFI LANParty P45-T2RS Turbo, embedded with P45+ICH10R and priced at $140.
You can buy E7200/ E8400 or Q6600/ Q8200 and DK P45-T2RS Turbo, it really brings good cost/ performance ratio.
The outer box is gloss laminated.
DFI LANParty DK P45-T2RS Turbo
Bottom left
2 PCIe x16
2 PCIe x1
2 PCI
1 Floppy
LAN: Marvell 8053
Audio: Realtek ALC 885, supports HD audio & 7.1 channels effect.
Bottom right
6 SATA II (ICH10R with RAID 0/ 1/ 0+1/ 5)
If you buy DK P45-T2RS Plus, you’ll see 8 SATA II here.
On-board Power/ Reset buttons + Debug LED, good to DIY and OC users.
Upper right
1 IDE 9by JMicron JMB368)
4 DDR2 DIMM (DDR2 667/ 800/ 1066; or 1200 via overclocking)
Upper left
4 phase digital PWM with 16 MOSFET, is quite enough for dual core/ quad core CPU.
One phase can provide 40W power, there is no LGA 775 CPU consume more than 160W.
I/O
6 USB 2.0
1 Gigabit LAN
Optical/ Coaxial Digital audio out
Red jumper for “Clear CMOS”
Black heatsink & heatpipe with deep color; for dissipating heat from MOSFET and north-bridge.
Platform
CPU: INTEL Core 2 Duo E8400/Quad Q8200
MB: DFI Lanparty DK P45 Turbo
DRAM: CORSAIR Dominator TWIN2X4096-8500C5D/TWIN2X2048-8888C4D
VGA: MSI HD4670 512MB
HD: Seagate 7200.10 320GB
POWER: CORSAIR 400W Power Supply
Cooler: Thermaltake V1 AX/JETART Nano Diamond
Bottom left
2 PCIe x16
2 PCIe x1
2 PCI
1 Floppy
LAN: Marvell 8053
Bottom right
Upper right
Upper left
I/O
6 USB 2.0
1 Gigabit LAN
Platform
