- Jun 1, 2003
AMD VS INTEL is the performance worth the price? Which system runs hotter? I hope this thread will help explain a few debates currently going on this forum and will aid you in your decision when picking out a system to build. Please no flaming! I am not bias toward either companies and I am happy with both systems.
Rig 1 $200 chip board combo
DLT3C XP1700 JIUHB AMD CPU
ABIT NF7-S version 2
SLK900u with ~50cfm 92mm fan
Aluminum case with sufficient ventilation
Rig 2 $375 chip board combo
2.4c Intel 800fsb CPU
ASUS P4C800 Deluxe
First we look at performance, both rigs are overclocked about 1 GHz and tested. The Intel rig is clearly the winner and don't even comment on the memory bandwidth we all knew that would happen. Not much more to say about performance but then again the Intel rig cost $175 more to build so if it did not outperform the AMD then we would not be buying it. If the Spingdale board was used then the price would be only $75 more for the Intel rig. If the AMD board was an nforce Epox 8RDA then that would lower the price of the AMD rig by $35. The chip and board combo for both are: AMD $190 and INTEL $375
The prices and board options have come down so if you wanted to buy now you could go with an 8RDA for $85 1700+ for $65, 2.4c OEM $175 IS7 abit $100.
Here are some pictures on performance when overclocked about 1 GHz.
AMD DLT3C @ 2.51 GHz XP core
INTEL 2.4c @ 3.4 GHz
So if you're playing to get a new rig and can't decide then this might help. You now know what it would cost for the board and chip combo and which one performs better and what speeds. A 2.4 GHz amd is = to a 3 GHz 533bus Intel, according to Sandra MIPS. If you go the cheapest route for both rigs, it's not guaranteed to hit the same speeds but with some work and maybe a mod you may get similar results.
What will have the biggest impact on system performance and stability is Motherboard, CPU, RAM, PSU and Temps. Skimping on a generic 250w PSU might get you wacked rails and an unstable system so please do some research and think about what parts you are using. Not all chips are created equal, some weeks, Plants, and steppings will outperform others. When a system is unstable at a certain FSB no matter how much voltage you give it and you feel it can do more please check what speed you're ram is running at or try to find the best known bios. The forum is full of great people and information; please familiarize your self with the search button as well. GL with whatever Rig you decide to purchase.
Both systems are often talked about and since I have both rigs I know where you guys are coming from. I love both rigs and each has their advantages. The intel rig with HT is a little bit smother with multitask obviously but as far as gamming and performance they are almost identical. I can tell the intel is a little faster but not jaw dropping faster. The only ways I can truly tell is with benchmarks but from everyday surfing or gamming both rigs are similar. I am truly pleased with both rigs and don't regret anything. The only thing I would say is if you are planning to spend more then $175 for a CPU then definitely buy intel 2.4c because the 2800+ can not beat the 2.4c overclocked. The only AMD CPUs I would purchase are the ones under the $150 range, anything above that you just can't beat intel. But anything under $150 for intel just can't beat AMD.
TEMP:
A lot of talk about AMD runs hotter then INTEL. I have ran some test at different speeds and voltage for my rigs and here are the results. The AMD TB core at 1.5v default runs cooler then the Intel northwood D1 chip at 1.525v default. The only way the AMD will get hotter is at a higher vcore like .1v more.
The asus overvolts a little and at load it drops to about default vcore set in bios, the abit board does just the same.
amd @ defuatl core and speed
intel @ default core and speed
Clearly the AMD at default core and speed idles lower then the intel.
amd @ load default core and speed
intel @ load default core and speed
Clearly the AMD at default core and speed even at load has lower temps then the intel.
amd idle @ 1.6v 2170 mhz
amd at load temp 1.6v 2170mhz
intel temp at default speed at 1.6v
intel load temp at 1.6v default speed
Now with a bump in vcore set to 1.6v in bios for both rigs the amd even with a 700 MHz overclock the temps are still lower then the intel at default speed with 1.6v
amd at 1.8v 2400 MHz idle
amd at 1.8v 2400 MHz load
intel at 1.6v 3480 MHz load
intel at 1.6v 3480 MHz idle
Now with both rigs overclocked with a decent MHz and decent vcore we see closer idle temps. The 1.8v for the amd will idle slightly higher then the intel at 1.6v but at full load will be much cooler then the intel rig. This concludes my test with temps and vcores. The amd appears to run cooler even with a little more vcore. Both rigs were idling for 10 mins before I took reading and same time for prime. The test would be better at 2hrs but 10min should give you an idea of results.
ASUS P4C800 Deluxe
TEMP:
