If I'm not mistaken, most boards these days take the temp reading from the diode, so whatever the board says is probably from the built in diode. Could be wrong, though . . .
Unforunately, your board doesn't have the on-die sensor support. In order to read on-die, you must have a board that has the support e.g. Epox 8K3A. However Hoot had designed a device that you would solder to the back area of the CPU which would add sensors to allow you to read the on-die sensor. He actually made them in bulk so he doesn't have them anymore
