- Sep 9, 2004
Hello guys,
Obviously, I'm new here and this place was recommended to me as "the place" for any and all oc/cooling related stuff so here I come to you with my little project.
I'll be honest with you guys, this is going to be my first solo WC project so I definitely want to do everything right the first time. I've, well...assisted in building a few wc-ed machines but have never built one of my own. All meaning I'm not a total noob nevertheless still a noob.
WC kits are not an option because anything that is out there is always missing a few pieces that I feel I should have, therefore DIY is a way to go.
With that out of the way, let me tell you what I already have coming, some of my system specs, case configuration, how I want all that to look and than the questions.
I've already ordered DD RBX 1/2OD, Hydor L35, DD NV68 3/8. This is all going into a system made out of A64 3800 on MSI K8N Neo2, with GF6800GGT, with 550w True Power, sitting in an overcrowded Antec SX835II case. The case, although big, is totally full: 2 optical, floppy, 3HD's, Audigy 2zs Plat, ATA controller card, 3 case fans and a GT. So I have no room for a decent wc cooling. Maybe I could fit a pump inside but that's about it. For obvious reasons I plan on having the rads & reservoir outside. My goal for this system is silence and performance, with emphasis on silence.
This is what I've been looking at for other components: 2 120mm Black Ice Pro or Extreme (probably blue), 2 92mm Enermax Blue fans with s/c for the rads, tygon 1/2 od tubing, still haven't decided on a reservoir. I plan to build a custom metal or wooden casing for all that, depending on the final specs of components and either keep it on the floor or on top of the case. What I read in GreenPsycho's review ov NV68 block is what made me decide to go with two separate 120mm rads in parallel vs one 240mm that I initially intended. I would like to avoid added heat from the GPU in the loop. Since I have no room in the case my initial idea was to mount the rads outside on a side panel so I'm still considering that option. I am really not after the looks and flash with this system, hell my case is still beige. What I intend to have, after everything is said and done, is a quiet high performing rig. The GT will probably be clocked @ ultra speeds 24/7 and CPU @ 2.5ghz. I also want some overhead for benching and stuff.
So that's it.
Now a few questions. Would it make sense to "Y" split the line going to the blocks and have two separate ones for each the CPU and the vid card and would this hurt the flow too much, in other words what sequence you think would be better/best? As far as rads are concerned, will I see a big diff between B/I Pro & Extreme? I assume Hydor L35 will be able to handle the flow for the entire loop. If I go with Vantec Stealth fans are the temps going to rise much with these rads (3-5C would be tolerable). Would you guys choose a 5 1/2 bay res or a cylinder one, another idea is a T-line with fillport on top of the case...basically give me an idea.
Now I humbly ask for your suggestions in all aspects of this projects, from choosing and combining parts to mounting, possible conflicts/complications and so on. Thank you guys in advance!
So that's it.
