Giblet Plus! said:
There is a very marginal temperature difference between air being pulled in at the bottom of the case and air being pulled in at the top.
My advice was predicated on the fans pushing out from the case, not pulling in.
In my case there IS a difference in temp from the case floor to the case roof.
It is heat that is already being dumped there thanks to the heatsink fan. If he retains good case airflow case temps will stay the same and the radiator will be cooled by cooler air. A decrease in the temperature of the air entering the radiator by 2C will decrease the processor temp by exactly 2C.
Part of the reason that I switched to watercooling was to eliminate some of the case fans and the associated noise.
My radiator was originally mounted in the lower front of the case.
I tried the fan in both configurations ( intake from outside and exhaust to outside) and found that while the CPU temp varied not at all, dumping the exhaust into the case raised the HDD temp ( HDD located directly above the rad) and the video card temp.
So I chose to exhaust OUT of the case.
No, the bigger and greater number of fans you have, the slower (and therefore quieter) you can run them while retaining the same level of airflow. I am currently redoing my setup to use 4 slow 120x38mm fans on a dual sized heatercore.
No matter how you cut it, running at the same speed and same voltage, adding another fan adds noise.
Since his stated objective was to lower the noise level, it hardly seems unreasonable to suggest that one fan will be quieter than two.
I appreciate your enthusiasm for watercooling but I would also appreciate it if you don't post personal opinions and beliefs as facts.
Fortunately for me, my beliefs are BASED on facts.
I was simply recommending a setup based on what has worked well for me.
Presumably you are doing the exact same thing.
Your condesension is misplaced.
