- Jul 26, 2001
- Houston, TX
I just built a 1.2 Duron for my Beloved and I noticed that the temps where a little high. This is all according to MBM, the temp was 27C in the case and idle temps were around 47C. I used Hotpotatoe to stress the CPU for a little while and got the CPU temp up to 52C. Now the temp in my room is about 21C according to my other PC which has no case panels on. Her concern is noise and mine is the temps. I am using the retail HSF on it to keep noise down. Should I:
A. Add an additional case fan to the rear of the case?(already has
mounting place and grill) If so should it suck air in or blow out?
This would be in addition to the case fan already in the front
sucking air in.
B. Should I not add the additional case fan and instead get a
better HSF? Any suggestions for good cooling, low noise?
C. All the above? Add additional case fan and find better HSF?
sucking air in.
