Today I opened my casing just to clean it all from dust and everything. Simple job usually. When i had everything cleaned and back together, i had problems booting it up. Firstly there was no picture at all on the screen. I turned it on and off, (Yes the old usual) and I was pleased to see that it works. Logged into my desktop all usual. I got blue screen after that, it rebooted it self immediately and i didn't get a chance to look at the error code on the screen. I then had the problems of the blank screen, but on and off again i got it working. Its all working now, but windows sent me a error code and they had no solution at all. I print screen and copied the code, and if anyone knows what was wrong, i would be very grateful.
Here's the error code:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: a
BCP1: 8020072C
BCP2: 00000002
BCP3: 00000001
BCP4: 833AEFE9
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini122809-01.dmp
C:\Users\Chris\AppData\Local\Temp\WER-56468-0.sysdata.xml
C:\Users\Chris\AppData\Local\Temp\WER724C.tmp.version.txt
Also my System Infomation:
Asus P5KPL Motherboard
Intel Core2 Quad 2.4hz
4.0GB 667hz RAM
Nvidia 8800GTX
Windows Vista 32-Bit
I know thats brief, ask if you need anymore details.
Thanks
Problem signature:
Locale ID: 2057
BCCode: a
BCP1: 8020072C
BCP2: 00000002
BCP3: 00000001
BCP4: 833AEFE9
Service Pack: 2_0
Product: 768_1
4.0GB 667hz RAM
Nvidia 8800GTX
Thanks
