Reccomendations for a Raid card or card for more SATA ports?
TheGreySpectre
I don't actually think I need a raid setup, but I have run out of SATA ports on my current motherboard and I was hoping someone could recommend me a decent card (board has PCI and PCI-Express) to add some more. I am looking to add at least another 6 if not more SATA ports.
Thanks
Greyspectre
HDCHOPPER
Ahhh there are many sata port cards on the market ( fit into a plain ole pci slot) & some that just plug into usb connectors on the mobo for more sata ports there very cheap too that fit into the backplate area of your comp 4 sata ports = 1 slot window & you get female ends this way...so you dont really need a raid card per say...
But one of my fav's raid cards and not too expensive is the Adaptec 2405 has room for 8 sata devices in 2 fanout cables (4 sata cables for each fanout) & it works great with SSD's but going that way you get male ends
