Recent winchester 3000+ CPUs - what vendor, and what codes? Latest from newegg?
IMOG:
As you are gathering this info, could you edit your first post to reflect the responses. Maybe something on the lines of:
1.Good OC'er
2.Moderate
3.Sad Oc'er :)
Thanks mate!
S.N
Gregory_WE said:
Just received my A64 3000+ OEM from NewEgg:
CBBID 0451EPMW :(
Just to let you guys know how it went. I'm not exactly sure what voltage I'm running at, but it's 100% stable at 2.43 GHz 270 1:1. I have is set to 1.40V in the BIOS with the +10% option (if I use the regular settings from 1.4-1.55 for some reason it doesn't really work - the voltage doesn't go up). I'd think it would be around 1.54V... in CPU Z the voltage varies, anywhere from 1.568 to 1.583. I've gone lower and had it stable, but I really don't know what the true voltage is, since what I set it to does not have a strong correlation with what it reads as.
You know it, and with air cooling none the less!
I figure this thing just needs a little extra juice... I mean, a 100% increase over stock voltage isn't anything to worry about right?
There are quite a few CBBID 05xx Winchester posted, please fire them up and report results, so we can establish whether these CBBID indeed are OK or below average, ..., especially with good NF4 motherboards and good memory modules such as G. Skill TCCD.
3200+ Retail CBBID 0501DPCW
Ordered two weeks ago from Microcenter.com and got mine on tuesday.
Haven't opened it up yet as I'm still deciding on a mobo and whether or not to keep it
Okay, my 3000+ 0503 CBBID isn't all that great but I'm really not complaining as anything is a hell of a lot better than the machine I had before. It will do 2.4 at 1.6 volts, but even then it isn't all that stable and I really don't want to take the voltage any higher than that. For now I have it running at 2.2 @ 1.45 volts and I'm thinking that's where I'll settle down with it.
3200+ cbbid 2650 so far, max voltage 265x10, been playin doom 3 for about 3 hours. Ordered from new egg retail box shipped from california
A few weeks ago I got a 0451 CBBID 3500+ from Monarch for my DFI NF4-DR mobo. I wasn't expecting much when I saw it because I had seen that the CBBID had a mediocre reputation. Sure enough I couldn't Prime over 2.6ghz with 1.6v on air. I was planning on putting it under my Mach II this weekend but I didn't think it would help much.
Friday morning I went down to my local PC Club store and picked up a 3000+ CBBHD 0444. It actually ran to 2.6ghz at the default voltage! I'm still testing but it looks good right now. :beer:
CBBID 0451 EPAW
Newegg OEM
01/15/05
Havent o/c it yet , just burning it in for now . I can tell you its prime95 and S&M stable at 1.158 V at stock speeds if that matters :santa: :drool:
gonna try and up the fsb now with prime95 running small ffts :D
should put enough strain dontcha think :p
here's what my CBBHD i got from ncix.com can do:
real good chip here. they ship to the states with no problems as well guys.
Is it prime stable at those settings?
Mine will prolly do 2.7 but it isn't prime stable atleast not with mem @ 1:1 but my memory will do 275 just fine
Oh yeah
my chip is a 3200 CBBID 0503 Shipped from NEw Egg on 2/25ish
