my 0503 can probably hit 2.7. The most I tried was 2.65 but it is not prime stable. I guess it doesn't matter if it games fine and has yet to bsod on me so maybe I should try it
Dinzy, if you could test more with various voltages and settings for stability - reduce your RAM settings to pinpoint CPU stability, if possible. I would really like to know what the top end is for your chip.
Sorry for the wait... trying to get some time in to work on this set up. This is setup is for the folks at work and wanna clock it a bit to see what it does and then bring back down to normal operations. What i'm wondering is what multi does the A64 have and what can i expect with the Corsair extreme LL mem mod that I have? 2-2-2-5 PC3200. Can i push it up to 215-220 with same settings?
thanks for any info.
The multi depends on your cpu- a 3000+ has a 9x multi, a 3200+ a 10x multi etc. Your ram should go to those speeds, value ram typically does so your good ram should as well. And it will probably go further. If not, try a divider (some boards, mainly the nForce4 ones are flakey using dividers).
