Abit NF7 Rev2.0
Athlon XP 2500+ Barton - has extra level 2 cache so 3d apps such as games will benefit from this
2 x 256MB PC3200
simpleman, you couldnt have picked two other cards with such a big difference between them. One is a completely rubbish for gaming budget card, the other a moderately fast near high-end card. Id be ionclined to pick a Ti4200 (GeForce 4) or Radeon 9600Pro. These are the best of the mid-range cards available. I wouldnt touch the FX with a barge pole. They support Dirext 9.0 but their performance is appauling, lesser to the Ti4200. The NF7 is the best socket A board available so id suggest you stick with it, its proven to be a great all rounder and overclocks very well out of the box. Case? Chieftec, you cant beat the quality, you can get the same quality from Antec as they also use the design for mnay of the cases. They are sturdy, plenty of room for expansion and fans for good airflow, secure (lockable front and side panel) only bad thing is no removable motherboard tray but i personally would never use this
Craig
