- Nov 8, 2001
I have a 12 foot 1/2 inch OD copper coil, a 6 1/2 gallon fishtank, several feet of 1/2 inch ID vinyl hose, a 2.8 quart sealed tupperware container with fittings for 1/2 inch hose, a Rio 1100 submercible pump, pipe insulation, some distilled H2O, and some UV dye. Soon I will also have use of a mini-fridge.
For now I've got the tank on my desk, pumping H2O thru the submerged copper coil, into the tupperware reservoir, and back into the tank. I'm leak-testing what I've got, and making sure the pump likes UV dye and icey cold H2O.
However, as you can see I lack a few vital components. Give me some advice on what to do with what I've got, and what I still need to buy. Try to save me some money.
Edit: Hello lucky star number 7!!!
