Hi,
I'm looking for suggestions on building an above average machine dealing with a dedicated MS Windows application (running Win 7 Enterprise or Ultimate) using vector graphics in market trading systems. There is a possibility to run the Windows app in Linux / Wine if that makes any sense for the losses likely to be found emulating with Wine. I'm open to which version of Linux would be applicable for best results, but fairly familiar with Debian, not opposed to BSD flavors either.
I need to be able to support high compute cycles as much of what gets done is mathematical algos doing floating point, then further facing the application's relatively vanilla vector graphics demand that draws multiple price bars, indicators, histograms on charts and the like.
My concept is to consider a design that's equipped with a bios / chip set that makes overclocking feasible, in order to bring the system up "some" within reasonable limits of the discovered weakest link, to maximize throughput. Ram type / speed, CPU/core design, buss speeds and drive technology all being fair considerations, hopefully not to break the bank, but that I cannot state a fixed budget much beyond 1500.00 - 1700.00 USD, I'm sure will cause limitation if not even outright belly laughter. The oddball in the bunch might be a need to handle at least dual monitors and preferably 3 monitors, possibly as a single (3) headed graphics card.
Hopefully there's a few on the forums here that can say "Here's a reasonable and clever way to hit above average, covering most if not all of the concerns". I mean it would make no sense to jack up sub-systems, only to find pipelining or on-board cache supports or Math processing were ultimately huge bottlenecks. I'm simply not familiar with what is reasonably current, tested state of the art in specifying an entire machine that would give a reasonable balance of the description, within controlled cost.
Any suggestions or questions I could respond to further would be greatly appreciated.
Thanks as always,
Afp
Thanks as always,
Afp
