- Jul 20, 2002
I'm getting some weird results on a Red Hat Enterprise Linux Server release 5.9 (Tikanga) PowerPC build. I think it has two Power 5+ CPU's of 16 cores apiece that
have some sort of hyper-threading technology that makes them appear as 32 cores.
1.uname -a returns
2.6.18-348.el5 #1 SMP Wed Nov 28 21:23:52 EST 2012 ppc64 ppc64 ppc64 GNU/Linux
2. getconf LONG_BIT returns 32-bit (but it should return 64-bit right?)
When I look at some binaries I've compiled I get the following statistics when I run
file on them:
charmrun: ELF 64-bit MSB executable, cisco 7500, version 1 (SYSV), for GNU/Linux 2.6.9, dynamically linked (uses shared libs), not stripped
In /bin/ chown and chmod both indicate they are ELF 32-bit MSB executable, cisco 4500 or PowerPC, version 1 (SYSV), for GNU/Linux 2.6.9, stripped
What is a stripped binary as opposed to a not stripped binary?
I also forgot to ask, but why is a 64-bit Linux install using 32-bit core utilities? My x86_64 CentOS box has 64-bit versions of
chown and chmod.
1.uname -a returns
file on them:
chown and chmod.
