refresh rates....
YoungstaxGx
In windows i Use 1024 x 768 @85 refresh rate (that good?) and when i play counter-strike it goes down to 60hz refreshrate....is there anyway i can bring it up to at least 75 or 80?
thanks
Bull
Check your options in the game. You should have video options that you can set the refresh rate higher and the resolution. I have a few games that I had to do that with.
o770
this is a limitation of some of the nvidia detonator drivers. there is an utility called "refresh rate fix" for windows but unfortunately it cant work with driver versions later than the 27.42 (i think), so, if you have any previous version just reply and ill find out the link for the utility.
