To anybody who knows anything about refridgerators:
I have a simple. compact refridgerator lyring around and I need to put it to good use. I decided on using it for my watercooling and making it into a "water chiller" and something I can put some drinks into. There is one problem. I tried to use high efficiency, so I put the whole ice box in my water with the simple fact that water transfers heat 10 times faster than air. But the compressor gets WAY too hot. After about 1 minute of running, my water lost about 1 degree throughout the whole system, but the compressor and it's system get so hot, it automatically shuts off. I read up on refridgerators and compressors and found that there is a type of "coil" thing to absorb the heat of the coolant before it changes phases to get maximum results. What I wanted to do was take that coil system and transfer it to a radiator with a 120mm fan. This will solve my heat problem, but I don't know much about the coolant itself and I'm nothing close to being satisfied about taking one of those tubes off and just letting the coolant go into the radiator and the whole process of incorporating the radiator. I read that the coolant evaporates at a nice -32 C and that means if I release the pressure of those tubes, it instantly all comes out and I have no clue how to do this. Any and all help would be greatly appreciated. Hell, if you worked at Dupont or something and have a little something to say about the coolant, that would be greatly appreciated as well.
For a good reference, I need to be able to apply a radiator similar to what asetek did. Check out some pics of their fridges at www.asetek.com and you can see the radiator in the front. That is my ideal setup.
~Ben
~Ben
