- Oct 19, 2002
- Connecticut
Hello everyone,
i've been following posts on using mini-fridges for cooling and I thought I had come up with a good setup. I was lucky enough to get a brand new mini-fridge for $20.00, still packaged up from a friend of mine(Haier HSW02). After modifying it and putting the evaporator in an 50/50 mix of antifreeze and water(total of 2 gallons) I thought things were going pretty good. Over the course of a few days however I can run my system for about 3-4 hours with a cpu voltage of 1.85 and 14x166 for my 2400 cpu, I was getting a higher overclock at almost 2 volts on the cpu at 15x166, however because of something that has changed I cannot run my system for long at all.
I've double checked my insulation, no signs of condensation, no leaks, no lockups. I have a fan cooling the compressor on the fridge as well. The water block is making a good connection to the cpu as well.
If I shut down my system for a while, it takes the fridge about 3-4 hours to get my coolant back to negative temps(which is about -6F to -8F). I have a 265gph pump in my setup with 3/8" rubber hose that is insulated as well.
The water block is BEcooling's black edge waterblock.
About the only thing I can think of is that I maybe have too much flow? Possibly getting a smaller pump?
I have also tried a different coolant mix of 40/60 and 60/40. I would hate to think that it's the fridge.
I would appreciate any ideas, other than buying a vapochill or Prometheia setup, even though I would love to....
