vietp13 Member Joined Mar 20, 2003 Dec 23, 2003 #1 is there away to drain w/c without taking off the waterblock mount kinda lazy
rogerdugans Linux challenged Senior, not that it stops me... Joined Dec 28, 2001 Location Corner of No and Where Dec 23, 2003 #2 Depends on how completely you want to drain the system: rads and blocks are hardest to get completely empty. For a fast and easy way to drain a water cooling system add a T-Line to the lowest point and use a valve to close it off. Remove the plug from your upper T-Line and open the valve in the lower T-Line and the system will be about 95% empty in seconds!
