Registry Mechanic
ricksimm said:
:confused: What are the advantages of using a program like PCTools Registry Mechanic?
None really, reg cleaners are supposed to help speed your system up, remove obsolete reg entries from deleted programs and such, usually I do not notice a big difference though. A lot of them work pretty much the same.
This site has one of the best, jvtools, but he has started charging for it, there is a 30 day trial though.
Here is one I like, it's free and seems to do a good job.
http://www.hoverdesk.net/freeware.htm (Regseeker)
By the way, be careful with ANY registry app, if you don't know what your removing you can sometimes cause system crashes or worse.
Run a registry cleaner on the typical OC.com users well maintained computer, it won't do much.
Run a registry cleaner on grandma's 7 year old windows 98 install however... :)
Yep I ran a registry cleaner program on my friends spyware infested computer a week ago and it came up with about 700 fixes that needed to be done (to go along with the 1300 instances of spyware). After that his comp actually ran like the pentium 4 2.8 it is :D.
It is amazing what can happen to a computer without a properly configured firewall/spyware app.
