I've been working on a computer for a couple days now. Everything that can go wrong seems like it is going wrong. I just got it up and running for the first time, but then a scareware attack popped up (it was called smart hdd. I had installed no such program, "closing" the program wouldnt make it close, it wasnt a listed entry in add/remove programs, and "mysteriously" every time i ran the "uninstaller" it told me there was a disk error, just so we're clear that its a load of BS). I pulled up ccleaner, removed suspicious entries from startup, and then reset the computer. The bios was screwed up so that the main hard drive was disabled, and after enabling the hard drive, I cant boot successfully. Tomorrow I plan to load the hard drive into my main rig, scan it with malwarebytes, remove all of the viruses, run checkdisk, and then throw it back in the other tower. Assuming this doesn't fix the issue, is there a windows xp repair disk or option on the install disk? This isn't my computer and I promised the owner I would have it up and running in about -2 days, so I need a response asap.
