Remove first 35 chars in text File Window OS
trekky
I have a text file that I filtered to get a number and have only one line left in the text file
"test.txt:3: text2.txt:258:Raw Value : 39,716"
I want to take the last number which In this case is "39,716" and need to use is as a variable such as if larger then 20,000 go to X
but I am getting a false reading due to the first 35 chars,
so in windows through a command line or power shell (or something that can be scripted) I want to remove "test.txt:3: text2.txt:258:Raw Value : " and only leave "39,716" (or have cmd or PowerShell read the last number and create a new text file with the number inside
note 39,716 is a variable based on output of a larger output of a text file
thx
ebug122
Ontario, Canada
This thread may not be required anymore, but I thought I'd try it out in Powershell:
Contents of test.txt:
Code:
script.ps1
Code:
[COLOR=#008000]#Assign the contents of test.txt to the variable $file[/COLOR]
$file = Get-Content C:\Temp\test.txt
[COLOR=#008000]#Splits the line from test.txt into an array using a colon as the delimiter[/COLOR]
$result = $file.split(":")
[COLOR=#008000]#Select the last value in the array (39,716), remove the leading space character and output it to result.txt[/COLOR]
$result[-1].TrimStart() | Out-File C:\Temp\result.txt
Contents of result.txt:
Code:
39,716
pcgamer4life
Code:
script.ps1
Code:
Code:
39,716
This is probably as good a method as any. Simply removing the first 35 chars isn't going to cut it since there's (presumably) the potential for the first few values to have fewer/more digits which would throw you off.
You could also do it something like this:
Code:
PS C:\tmp\> $data = "test.txt:3: text2.txt:258:Raw Value : 39,716"
PS C:\tmp\> $value = $data.Substring($v.IndexOf("Raw Value : ")+12)
PS C:\tmp\> $value
[b]39,716[/b]
or
Code:
PS C:\tmp\> $value = $data.Substring($v.LastIndexOf(':')+2)
PS C:\tmp\> $value
[b]39,716[/b]
