Removing defogger
Tyranos
NM
How would you remove the defogger from the bridges if you feel that the gaps were not filled adequately during unlocking?
Über~PhLuBB
Jedi Knight Senior
Portland, OR
I use the edge of a credit card (or other plastic card, like drivers license or plastic school ID) and scrape off as much as I can, then use Acetone (nail polish remover) to dissolve the rest.
As a safety precaution, I use isopropyl alcohol to "clean" the Acetone off, because the nail polish remover I have has "additives" to make nails stronger (probably Keratin and Aloe Vera). I don't want any additive film over my chips. =)
maxima88
I use denatured alcohol. It's a lot more expensive but really works well in removing any conductive paint.
The-Fox
israel
I use Nail Polish Remover too, it works fast and very efective, leave no Marks at all...
Mr B
Senior Admin Emeritus
East Bridgewater, MA
Isopropyl (rubbing) alcohol works as well, but not as good as the polish remover (which I'm a bit leery of using, but anyways...)
Either should work....alcohol just takes longer...
