Removing Ramsinks?
cypher_138
NJ
I epoxied ramsinks onto my 9800XT with Artic alumina epoxy with a little AS5. Whats the best way to remove them without damaging the card?
cypher_138
cypher_138
NJ
Never mind. I found that I've been getting a kink behind the fan when I put my panel on @ the GPU WB. I'll have to use a 90 to remedy it. I also figure the warranty is voided on this card as is so I pulled the shim off of it. I didn't think heat would cause the problem I was having.
cypher_138
cypher_138
NJ
Hey Tawcan.:D I've seen a few post from you here and at EOC as well. You got to love a post where you answer your question before you get a response. I should have held off.;)
Tawcan
Vancouver, BC
Hehe~ :D Just browsing around...no more stay on one specific forum for me. ;)
