Replace MSI 1080 Armor OC Bios to Gaming X or Gaming Z
dgateles
Hello!
I woldlike to know if its safe to replace the MSI 1080 Armor OC Bios to Gaming X or Gaming Z Bios. Thanks!
Mandrake4565
Mr. Clean Senior Member
First question that comes to mind is why? Why risk bricking it, when you can just Oc it?
D
dgateles
Armor, Gaming, Gaming X and Gaming Z is the same PCB, the same card, just have a different bios and cooling system but some applications its only for Gaming series
ATMINSIDE
I don't see what the Gaming app gives you over Afterburner....
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
I dont see why not... but it is a risk. I would rather create a profile in MSI AB and have it startup and apply it.. but, you can try it...
It gives you less... its three buttons/OC choices. There isn't fine control IIRC...
