- Feb 23, 2001
I broke my clip for my fop32-1, as have many, and I purchased a replacement from 3dfxcool.com, but it was crap. It was much too weak, and I lost 10C! I need to find out where I can find a replacement clip for this hsf. Thanks.
alphacooler (Feb 23, 2001 08:36 p.m.):
kat (Feb 23, 2001 07:23 p.m.):
kanie hedgehog has a nice replacement clip and I will personally grantee it wont break hehe
just kidding ;D
Will the kanie hedgehog clip work? Or were you just screwing with me? Thanks for the reply nonetheless.
Monza (Feb 23, 2001 10:59 p.m.):
2cooltek.com has the replacement gw clip, its better than the stock 1, or if u want a good clip, u should go get a Vantec Hs.
good luck,
monza
amd tbird [email protected] (7.5x133)
"New" Vantec cooler (gotta love that clip)
Asus a7v133 motherboard
256mb pc150 kingmax (2-2-2)
evga geforce2pro 32mb
maxtor 30g
40x cdrom
zip100
linksys 10/100 nic
Monza (Feb 24, 2001 12:45 p.m.):
huh, 2cooltek.com and nerdsbyte.com had them, quess they ran out, i'd still email them on availability (definitely nerds, their fast and cool (no pun)). anyways, i found a link ....remember older gw's clips work with the fop and r preferred b/c they dont have 20lbs of pressure.
good luck,
monza
maxtor 30g
40x cdrom
zip100
linksys 10/100 nic
