Replacing PC Chips 810series mobo
Hookem
Houston Texas
System consist of above mobo with onboard sound lan and video, AMD 850mhz Athlon, Western Digital WD-300-BB 30gig ATA/100 hard drive, Deer 250watt power source that is not approved for the 850mhz Athlon and 256 megs of PC133 memory... System is very unstable and crash's...any suggestions???
I'd also check out you cooling..... is this a Slot A Athlon or a Socket A Athlon (Thunderbird)? Setting your memory more conservatively (i.e. CAS 3 instead of CAS2, interleaving disabled) can help with stability.
SickBoy
